I just picked up this bass tracker yesterday and we actually went on the water and did a test drive. It was a little hard to start only initially, but I did not notice this noise. Maybe because with the throttle your not revving up and letting off quickly, but I also notice it did not do it when in gear, only in neutral when throttling up via the cable.
I will probably change the lower end oil after work today and check that since the noise appears to happen only out of gear.
It kind of sounds like some kind of bearing failing or something, I am hesitant to think it is normal when out of gear. I'm hoping its an easy fix, if its super expensive I might reach back out to the Previous owner, I did pay via paypal so that could be a plus on my end.
https://www.youtube.com/watch?v=Zw61w0bncek
