Well..I think I just recorded some bad news. I picked up a motor that had not been run for a number of years. Before spending much time on a tune-up, etc., I took a compression reading on all six cylinders. The readings varied from a low of 75 to a high of 90 on all six cylinders with most residing in the 80 range. Prior to turning the motor over, I put in a solution of 2 cycle oil and marvel mystery oil and let it sit for a day. The motor seemed totally free but obviously seems to have low readings. Before I jump the gun with assumptions and incorrect conclusions (I do that alot!), is there anything else to check? I'm thinking my next move is to pull both heads and snoop around to look for scoring, etc.? I read JB's post on compression and it seems the bigger concern is the "delta" between the readings. 15lbs. is quite a bit between cylinder readings. I did not have the throttle open all the way. Is that a big deal? Any other thoughts? Thanks for your thoughts and advice.
