MikeyBoats83
- Joined
- May 10, 2010
- 15
This past weekend I was in the process of taking off my lower unit (seal leak). Working to get the bottom bolts off of the power trim/tilt, unfortunately 3 bolt heads sheared right off leaving the bolt inside (salwater corrosion im assuming). How do i get the bolts out?
Only thing I can think of is taking the motor off, drill until i can grip the bolt, and torch the outside until i can pull it out.
Any suggestions?
Any suggestions?
