rjcamel2355
- Joined
- Apr 22, 2015
- 221
Hey folks, got a 1999 3.1l ox66 200hp efi engine. It hasn't gave me any major issues to date. However I got on the lake today and noticed about a 6-800 rpm loss at wot, about 8mph on the top end. Got home checked the compression, 110 across the board on my China made gauge (same compression as when I bought it) I think the gauge is off. Anyways, I ran a ring free shock dose in it last trio out along with the marvel mystery oil I run in each tank. Each spark plug is black up to about th bottom 4 threads, porcelain in the center is tan with maybe a slight hint of red in it. I will get pictures in the am. Cleaned the o2 sensor last week, lp pumps replaced less than a year ago. All plugs seem to be firing. There is no miss that I can feel but these engines idle rough I know. Boat still jumps up on a plane and runs 55-58 with a full load but only at about 5100ish rpms.
I guess my question is, are my plugs possibly dry fouled with carbon? None of them were wet with fuel or oil, but they have a little over a years worth of heavy use on them.
Anything anyone would recommend? Am I looking in the right direction with the plugs?
The hint of red is running hot if I'm not mistaken, I had a poppet valve sticking but I replaced it with the mushroom style, there was never an overheat alarm and the least psi it ever had was 12psi at wot
Appreciate any and all help guys, hoping to get back in tip top shape by the weekend.
Thank you.
Thank you.
