J200TXEIB 1991 Johnson 200hp.
I removed the thermostats when I bought this boat about a year ago because I thought I had a overheating problem but it ended up being carbs, tuneup, and electrical issues. I got all that repaired.
I have been running it without thermostats since last fall and it seems to be ok, But my question is: Will it run to cool like this?? and will this keep in in the Quickstart mode??? How do I test the thermostats?
I can blow through both thermostats with my mouth with them at room temperature, but one is a little more open than the other. These are the black cone shaped with a spring. I'm afraid to install them without knowing if they are ok.
I need some advice.
I need some advice.
