2011 Nissan TLDI 50 FFP Issue (NSD50B2)
Backriverfish
Hey Everyone,
I replaced my FFP on my Nissan today and I'm still experiencing some bogging down issues. I've gone through the entire fuel line, plugs, replaced the fuel pump.. When I tested the FFP prior to replacing it I found out that is was no good. When I ran today the motor was fine running for about 15 minutes then I experienced it bogging down for a few seconds and managing to regain power. I had the same exact problem about 3 years ago and replacing the FFP solved the problem. Battery is 1000 CCA and wiring was new this spring.
Thanks
pvanv
Did you reset the TPS initial value? Did you read out the ECU memories in diag mode?
