2017 Honda BF115 Beeping
MthTrains01
I just bought the boat earlier this summer with a 2017 Honda BF115hp outboard. Every now and then, after I start the engine, the engine light comes on and it continuously beeps. Ill shut the engine off and try a couple of more times and the engine light won't come on and no beeping. No issue with the water flow through the engine and I just did an oil change after purchasing the boat. Any thoughts what might be causing this?
MattFL
Check (or have checked) the oil pressure sending unit. Put a pressure gauge on it and figure out if there actually is oil pressure when the buzzer comes on. Or just replace the sensor and see if that resolves it. If you really do have low oil pressure then you'll want to resolve that immediately. Also double check the oil level and make sure they put the correct filter on it.
