20hp mariner 2000rpm at wot
PETER JAMES
Have just brought this 13ft alum.Savage with a<br /> 20hp mariner long shaft with elect. starter <br /> ser.08270200 89 model with CDI ignition and a<br />integral fuel pump carburetor with primer system.<br />It had not been started for 2 years, has fresh fuel<br />has good spark on both new plugs have pulled apart<br />carb cleaned and replaced primer diaphragm all<br />other parts looked ok. Motor idles ok runs up to<br />2000rpm at wot no miss should run 4500-5500rmp <br />allso have checked fuel tank, lines,filters etc.<br /> allso check compresion 120psi both cylinders .<br />any ideas? :confused:
JB
Re: 20hp mariner 2000rpm at wot
Moving to Mariner Troubles.
