I have an older 20hp merc tiller steer. The serial number is gone so I have no way of knowing exact year. If I had to guess Id say late 70s early 80s, Black w/blue band around the cover and it says "thunderbolt ignition system" on the front cover. Ok, the problem. It will start up and run great from idle to wide open sometimes 10-15min sometimes an hour then it stalls. It starts right back w/a pull or two of the rope and runs great. Stalling always happens when im running wide open. Any ideas? Also, if I leave the motor up on the latch (which I must to keep the foot from draging the ground when trailering) fuel leaks from the carb. It dosen't seem to happen when the motor is in the upright running position. Is this normal? I really appreciate any help yall can give!
