Tony T.
- Joined
- Jun 5, 2007
- 178
Recently bought a 21' Suntracker fishing barge that had a bad powerhead, 70hp Force. I had a 75hp Mariner that I mounted on the Suntracker.
My question is, does the cavitation plate on my motor need to be even with bottom of the toon? I used the second set of holes on my motor not really thinking about it at the time and just today I decided to measure with a level from the cavitation plate to the toon. I marked it and measured from the mark to bottom of the toon and it is 3".
What do you guys think, should I go ahead and move the motor now down to the last set of mounting holes or try it out first with the 2nd set of mounting holes?
I got every thing hooked up except the power tilt and it's a make shift set of jumper wires I rigged up to lift the motor up and down for now. Also could you recommend where to buy a 3-wire harness kit for the power tilt, The original harness was wired into the Quicksilver control box and I wanted to keep it complete.
I'll try to get up some pics of the motor mounted here soon.
I do figure I'll have to trade out the prop also it's a stainless 13 1/4x 20 that's on the 75hp Mariner now, the Mariner was mounted on a 15 1/2 ft Skeeter F-80 bass boat.
Thanks for any info
Tony
Thanks for any info
Tony
