225 ocean pro (won't start)
could be just the photo ... but the fuel looks yellowish
may not be an issue but do you know how fresh it is or was.... was it stored with fuel saver additives for long term storage.
see video
I hope this isn't a dumb response but the previous owner bypassed the oil "pump"? I mix the oil in the gas when I fill up. Maybe that's the discoloration?
havoc_squad
Recent US federal law in 2021 adds teeth to federally controlled waters against one who removes it or does not use engine cut off lanyard while under way.
In short, get stopped and its not attached properly on the operator for a boat with it or late model boat, expect a ticket.
I'm not sure what your comment is in reference to? I wear an engine cutoff lanyard every time I operate. And have never said otherwise.
deleted after last post ..clarifying that starter does turn
well starter fluid should have done something... how's the 20 amp fuse
does T&T work
can you check for sparks
any lainyard safety pulled out ?
see older diagram example ... fuse feeds T&T and... ignition on that version
try to check all connector points for loose or oxydized connections (pull apart clean & reconnect)
Ahh this is awesome. Thank you very much!
havoc_squad
Gotcha. Sorry. Didn't see all the other threads. But I checked that and it seems fine. Appreciate the advice though.
Yeah, it was just a public service announcement because its only been about 1 year ago since that US law took effect and there are many who don't know still.
Crosbyman
no not a dump response ... if the fuel is fresh it is a non issue. ... just going by the color which seems..yellowish a bit
Crosbyman
Safety lanyards are a navigation hazards. Engine is designed to run without.
Have not used mine since neethe
You are here: Home / Cruising & Chartering / Outboard Won’t Start 101
Outboard Won’t Start 101​
Published on November 27, 2017; last updated on September 19, 2021 by Carolyn Shearlock
Trouble starting your dinghy or sailboat outboard engine? Here are a few things you can try before calling for help.
Pin it!
So, your outboard won’t start. What are the likely causes? What should you check first? Second? Third?
It doesn’t matter what brand of outboard you have or whether it’s 2-stroke or 4-stroke. 95% of starting problems are caused by the same group of things and don’t require a mechanic. In fact, only one of the things to check even requires a tool (and that is just a small flat-blade screwdriver); that screwdriver and a roll of tape (I like Rescue Tape — read about it here) are all you need for any of the simple solutions and jury-rigs presented here.
FOUR CLUES TO WHY THE OUTBOARD WON’T START​
Start by noticing important clues as to the cause:
  • Sometimes the motor will sound like it’s not even really trying to start; other times it’ll sound like it’s almost starting.
  • Is there an external tank connected by a fuel hose?
  • Do you smell gas? (If so, immediately extinguish any cigarettes or other smoking materials! Actually, extinguish them before doing any of the fuel system checks.)
  • Does it start okay, then die when you put it into gear?
Admittedly, there are going to be times when there is no simple fix. If you’re a mechanic-type and know outboards, great. If not, find someone who is. BUT — and this is the important part — the vast majority of problems do not require any special knowledge to find and fix at least well enough to get home.
THE FIRST THING TO DO WHEN THE OUTBOARD WON’T START​
If you’re not tied on to your boat or a dock or anchored, the first priority is to not get swept away from safety. Row or paddle back and tie on or drop your dinghy anchor.
And as a side note, always have your basic safety gear in the boat — see my article on Things to Carry in the Dinghy.
WHAT TO CHECK WHEN THE OUTBOARD DOESN’T SOUND LIKE IT WANTS TO START​
Four(or five with an electric start) things to check when the motor doesn’t even sound like it wants to start, regardless of whether it has an internal or external tank:
Kill Switch​
Make sure that the kill cord (aka “deadman”) is attached properly to the motor. Don’t just look at it — generally, if it’s even a tiny bit out of place, it will stop the engine — or prevent it from starting. I will undo it, and then put it back into place. In my experience, this is the most common cause of failure to start! NOTE: Always wear the kill cord — read more here about why and an easy way to do it if you need your hands free.
dingbat
Some folks bypass the lanyard.-----That might be frowned on by some agencies like Coast Guard.
@IDFISHER
It's not by-passed.....the functionally is outlined in the Operator's Manual.
"In an emergency situation, the engine can be started without the clip in place. Follow the normal starting procedure. Reinstall a clip as soon as possible."
My boat is Coast Guard inspected every year. One would think they would have caught on by now if that was a big concern. ;)
