1. speed sounds OK, but rpms are down - assuming the tach is correct? Seems like they should be closer to 5k? You'll need to research that. If true, you might pick up some performance by dropping to a 13x17 or even a 13x15
2. 3 blade vs. 4? I wouldn't unless I had the need. Maybe a little extra power out of the hole, or better thrust available in reverse?
