24 volt trolling batteries used for emergency starting?
nightstalker
If a boat has one 12 volt starting battery and two 12 volt trolling batteries rigged for 24 volts for a trolling motor, is there a way to use this 24 volt system as a backup for starting the engine if the single 12 volt battery dies? Can you use jumper cables, battery one/two switch without blowing the 12 volt starter?<br />Stalker
KM2
Re: 24 volt trolling batteries used for emergency starting?
Just jumper or use ONE of the trolling batteries . I have just pulled my starting battery put the trolling battery in and started up.
nightstalker
When you say jump her, do you mean using jumper cables from one of the trolling batteries to the starting battery? Do I have to disconnect the two trolling batteries so that I'm not jumping 24 volts?<br />Stalker
Silvertip
If you connect jumper cables to the POS and NEG of just one battery (either one), you will only feed 12 volts to the engine. No -- you don't have to separate the two batteries in the 24V system. Just be sure to connect both jumper cables to the SAME battery!
PAkev
Upinsmokes got it right, <br /><br />I went out the other night and fished for a few hours without even starting my outboard. Although I got around with my trolling motor, my nav lights and fishfinder sponged a little too much power from my cranking battery when it came time to start the outboard. Luckily enough I wasn't terribly far from the ramp and had jumper cables in my truck. I hooked them up as upinsmoke indicated and started the big motor right up. <br /><br />I am currently in the process of making up two jumpers out of Heavy duty wire and about 3 ft long with eyes on both ends that can be easilly screwed under the wing nuts and can be easilly stored on the boat.
nightstalker
Thanks for the help. <br />Stalker
