24 year old card floats
mcgill
Hello l have a Yamaha 150 pro-v qesttion when do you change the carb floats. The boat is 24 years old
And the carb float are that black looking plastic. I tested the carb floats in water no bubbles is it Time to change?:facepalm:
robert graham
Re: 24 year old flots
Are you referring to the carb floats?...if so, why do you have them out and why would you change them? :confused:
Handyman1
Unless there is a hole in them or damaged i wold't touch them for another 24 years.
Handyman1
O sorry i forgot you have the leaky carb ok now 1st you check the shut off needle for any damage same for the seat if everything checks out ok then you adjust the float by the book.Ps starting 3 thread on the same problem that does not help you.
mcgill
some one telling i need to change them
Handyman1
If the float is good you do not have to change it. if there is damage on the shot off needle or the seat that is what you have to fix. or you might just have to adjust the float
