Re: 24v to 36v
A two-bank charger is really two independent 12V chargers in a single package. With three batteries, you will need a three bank, or use the two bank for two of the batteries and use partable charger for the third. You could add a new single bank charger for the third battery if you don't want to relace the current charger. Your owners manual for the new motor will have motor current ratings and breaker requirements. Plug should be ok. You will need to move the positive wire (red) (or the breaker) on the current battery to the positive post of the new third battery, and run one new wire between positive on the second battery and the negative on the new third battery. You will now have 36 volts at the plug. Sounds more complicated than it really is.
