goblerblaster
- Joined
- Dec 26, 2011
- 180
My 2010 model 25 hp Etec is giving me fits. I have only used it one time since last summer. Go out and put it on the garden hose and it fired right up, ran it for a few minutes and figured it was good. Got it to the lake a few days later and it fired right up, take off, and it is running fine for about 5 minutes at 3/4 throttle. Then it kinda acts like it is dying like the vent on the portable gas tank is closed- but it is open- then picks right back up and runs for another 2 minutes perfect. I stopped and let it idle for about 3 minutes and it then died. It would restart, idle rough, and die every time I put it in gear.
Sometimes, it will start right up and idle at about 1000 to 1500 rpm for 5 to 10 minutes and then die -just like it runs out of gas. I can see gas in the fuel filter, even when it acts like it ran out of gas. Most times, it will restart, idle for a few seconds and die. Next day, same thing- crank immediately and run for 5 or 10 minutes and die.. Some days it will hit, crank, sputter and never run or idle.
I called the local Evinrude dealer and explained my problem. He said he was no longer a dealer and would not work on an ETEC engine ever again coz of all the probs he has had with them !! He said he thinks it is the vapor separator and there is a long history of these failing.. I have researched the web and put a 50/1 oil to gas mix in the tank and it doesn't to have changed anything. The longest it has run is 19 minutes, it is pumping water, etc. the water coming out of the lower unit does not even feel warm ( Air temp here has been in the 40's most days I've messed with it)
Any suggestions on what to try? Or just get the $300.00 part and take it?
Thanks
Got it home and have started it many times
over the last few weeks..Sometimes, it will start right up and idle at about 1000 to 1500 rpm for 5 to 10 minutes and then die -just like it runs out of gas. I can see gas in the fuel filter, even when it acts like it ran out of gas. Most times, it will restart, idle for a few seconds and die. Next day, same thing- crank immediately and run for 5 or 10 minutes and die.. Some days it will hit, crank, sputter and never run or idle.
Thanks
