Put a 25 HP powerhead i had in shopcorner for years on a 35 HP midsection, for my brotherinlaw. Maiden voyage showed it had a clicking sound. The screwdriveron- pistontoptrick-, showed something like 1/64" play in lower connection rod. Before I even waist time to pull everything apart: Has anyone experienced a rod bearing failure that was fixable without changing cranckshaft and connecting rod or even connecting rod. Im' running out of parts for these, I repaired quite a couple thru the years. Only bearing failure I've seen was including chewed up cranckshaft journal. Worth the time ??
