25 HP 2stroke. 14' Utility, Best Prop Pitch
catalyst-519
I just bought a 1996 25hp short shaft. I have it on a 14' aluminum utility that's had a couple padded seats and a small deck installed.
I had to raise the trim pin up to it's 2nd highest setting or else the stern drove itself into the water at the top end. Is this normal?
Also, it needs a new or prop or a rebuild. Right now is a 13" pitch (which I assume may be stock). Believe it or not the boat is a little slow on plain and looses complete power during a moderately sharp turn.
Should I stick with the 13" and have it rebuilt or should I just get a new prop with an alternate pitch?
Thanks
