25 hp electric start Johnson
16ftsunbird
1973 25 hp Johnson model 25R73 electric start i picked this motor up today in front of it there is a set of male plugs looks like where the cables from the battery would plug into for starting the motor can anyone tell me where i may b able to pick this plug up from or can i bypass and put starter switch of some sort there for starting and shuting the motor off
flyingscott
That harness is NLA you will have to make your own. Even if you could find a used one the wire they used back then did not hold up well it will probably be in bad shape. Better off bypassing it just remove it and put a key switch in there,
A new one is available I believe but likely out of your budget.-------------It was a convenient way to install / remove motor from the boat.----Find a wiring diagram and bypass that set-up.----------Mount the solenoid inside the cowling and add a push buttom or remote switch just like models from 1990's.
16ftsunbird
I had thought about a key switch going there just wasnt sure bout the wireing to the switch so it will charge the battery back it already has a solenoid inside the cowling tks for any input & tks for the responce
Is your motor equipped with a battery charging coil,---- yes / no / do not know ?
hardwater fisherman
I do not think they offered a charging system on the 1973 25 hp models. But I could be wrong. Also if the model number is 25R73 then it might of left the factory without electric start. I believe the model number for an electric start would be 25E73.
hardwater fisherman
No Title
This is a parts breakdown from an electric start 1973 johnson and there does not appear to be a charging coil present.
F_R
1973 did not have a charging system!! The electric start was an add-on accessory, available as "remote" with switches up forward in the boat, or "standard" with a push button start where your plug-in is now located. All you need to do is remove the plug and install the push button parts.
16ftsunbird
i'm not sure about a chargeing coil but i'm sure the model # is 25R73 i'm sure it's electric start with a soleniod & with an electric choke the plug thats there is 2 big lugs and 4 small lugs was looking to wire it where the electric choke and all will work thats why i was thinking of a key switch any help pl
flyingscott
Use a key switch that has the choke built into it. Then find a spot to run the battery cables
16ftsunbird
Oh an on the soleniod there is 4 wires on it 1 on each big post & 1 on each little post if this helps any
F_R
Back to basics. How do you plan to run this motor? Up-front remote controls, or tiller steer at the motor? Set the motor up accordingly.
16ftsunbird
it will b used as Tiller Steer how can i tell if it has a charging coil & how many poll switch will i need to use can the wires b pulled from the harness that is there now and b wired to the switch to supply power and to kill power
Any wee yellow wires coming from under the flywheel ?-----------Any wee yellow wires going to a rectifier ?-------------Posting some pictures would make that easy to identify.
16ftsunbird
i'm sorry i don't know how to post pic's but the only thing i c from under flywheel is 2 blue wires inside a black liner coming out going to the coils marked 1 & 2 and this is whats in the wire harness 1 large red wire going to the soleniod 1large black going to grd 1 white wire going to small post on soleniod 1 small red wire going to electric choke then 2 small black wires that plug into the wires coming from under the flywheel i picked up a Sierra MP 39710-1 Ignition Switch today its says RED TO BATTERY BLACK TO MAGNETO GRD BLACK w/YELLOW STRIPE TO MAGENTO does this mean to the black wires from the harness PURPLE TO IGNITION WHAT DOES THIS MEAN BY IGNITION YELLOW w/RED STRIPE TO SOIENOID THAT WILL TIE IN WITH THE WHITE WIRE AT THE HARNESS and the YELLOW w/BLACK STRIPE TO CHOKE THAT WILL BE THE SMALL RED WIRE IN THE HARNESS i hope i did'nt miss anything
I would say no yellow wires from under the flywheel = no charging system on it at this time.
F_R
The instructions that came with your new switch are for newer motors with "new" color coding The wires on your motor are confusing because you have an accessory starter kit. So here is hoping I get this correct.
The blue and blue/white stripe wires going to the coils are the stop wires. They will lead to the two "M" terminals on the ign switch (black and black/yellow on new motors)
The small white wire on the solenoid is the start wire. It will lead to the "S" terminal on the ign switch. (yellow/red stripe on new motors)
The small red wire is the choke wire. Goes to "C" terminal on a push-to-choke ign switch--whatever color they are now.
As I said, I hope I got it all
BTW, there is no charging capability on your motor.
16ftsunbird
Ok just to clarify connect wires as u have stated the purple wires on the switch will not be used which would have been going to ignition and assy am I correct
16ftsunbird
Can these wires be tied directly into the wires in the harness that's there or would it be best to remove the harness and run wires from new switch all the way and tks a bunch oh can a charge system b put on or would it be costly
