huckelberry
- Joined
- Sep 1, 2008
- 56
I have a '78 25 hp evinrude that when I have it at idle speed, especially in neutral, it will cough and shut off. When this happens the bulb is usually limp and needs to be pumped again. When I pump it back up it will Idle good for a couple of seconds, then cough and shut down again. I had a boat shop repair the power head to get it running so I am sure it is not a carb or fuel pump problem. I also replaced the bulb. The hose looks good, the clamps are tight and the line connectors don't leak. This shutting down is really bad when I am trying to trailer my boat at a busy landing by myself with a 10 knot current. Thanks for all the help you can give me.
