25 hp evinrude thermostat
huckelberry
My '78 25 evinrude does not have a thermostat. I plan to use it a lot this winter. What kind of trouble can I expect with running this motor with no tstat in cold water.
HighTrim
Re: 25 hp evinrude thermostat
You should replace that 'stat ASAP, it is needed. Remember, tstats control min temperature, not max.
Without getting into mechanical theory, the t stat is needed to keep the engine running at an optimal temperature, preventing severe damage to the piston and cylinder wall.
Some motors will actually overheat. The necessary cooling water from the water pump is never quite filling the block, hence the top cylinder overheats. Some cooling systems actually rely on that t stat for a restriction, since the water is exiting quicker than it is being replenished. Removing the stat is also horrible for a water cooled rectifier/regulator.
The rings will wear out quicker (not by much, but quicker none the less), and carbon will build up as already stated.
You have to have faith in the OMC engineers, they get paid the big bucks, and if the bean counters could have talked them into scrapping the t stat, they would have Im sure!
Bottom line, I would replace it.
Mas
Also, the oil does not lubricate properly when cold! It is not as fluid! Most engine wear occurs during "warm up" with a properly functioning engine!
MAS
huckelberry
Took it apart last night. Thermostat stuck open... ?!. Got new gasket, seal, and tstat for under $20.00 at jonnyrude dealer. Also the gasket came off with little trouble. I just knew that when I took it apart that I would break and or wring off a couple of bolts and ruin the cylinder head trying to get the old gasket off. A suprisingly cheap and easy fix.
Thanks to everyone for all the help and advice.
