Re: 25 hp johnson fuel mix 100/1 ?
well guys great success.Got a volt meter put it on the ohms scale and read between the 2 leads of the coil the manual say's it should read between 250-300 ohms one said 264 the other zero i had an old coil and the # matched also took continuity between both spark plug wires and nothing. so i redid the heads" of the spark plug and she started right up but had to shut her down there was no water coming out of the tellall.I almost feel like a certified mechanic "ya right" well thanks for the help guys and I'll keep you informed about checking out the water flow problem also what is that knob, it looks like a choke but when i pull it out it goes right back in it feel lik i am priming the carburator with this is that what i have to do pull back and forth to prime this i have never seen this
