It is a 2 cylinder. Reason I am asking : Was having problems with top cylinder igniting. Had great spark, both cylinders at 100 lbs. Now it is running fine but I am curious why. I sprayed parts cleaner up under the flywheel with out removing it and am running the motor on a stronger mixture of gas oil and sea foam. Was curious if Something under the flywheel got cleaned just by luck or if the added octane is a temporary fix.
