I have a 1980 Mariner 25 H.P. Motor runs fine, just hard to start with out a small shot of carb cleaner. I have removed carb and cleaned it, Compression is good. Any ideas?
I will post serial number online at 4pm eastern time. It has choke with only a wire running from it to choke knob. The choke assembly does work with it.
I have my motor set on remote steer. I have the tilt on the 3rd area from hull instead of straight down. I wonder If I move motor into the straight down position.
Does any one have any more ideas. Choke works. Full in carb bowl and filter and lines full of fuel. But motor will not start without a shot of carb cleaner. I don't wanna use it. I have cleaned carbs inside and out.
