floatmiboat
- Joined
- Sep 4, 2010
- 90
I'm having the following issue. I have a 1997 25 hp merc 2 str with remote controls and a pull cord. I can't get it to start with the key, but it will start with the pull cord and the key turned on, there is no click at the solenoid and I can jump straight from the battery to the small hot solenoid terminal and the engine starts. I can also read 13 volts at the large solenoid terminal on the battery side with the key turned on, but nothing at the small hot terminal. Does this sound like the neutral safety switch has failed and if so where is it located?
Tried getting the cover off of the remote controls but the screws are spinning, guess I'll have to drill them out if it's located in there, thanks.
