I have a pull start 1993 Evinrude 25 hp, model number E25RETS.
I want to install a trolling motor (probably a Minn Kota 40 lb), running lights, fish finder/GPS and a tach.
A) Will this motor have enough output to keep a deep cycle battery charged?
B) Or should I keep it simple and skip the expense of the outboard charging package which I assume I can locate and I assume will run around $150
and not bother with the motor charging the system and just pull the battery after use and charge it overnight?
C) ???
If I go with B how long would I be able to run that set up with a battery in the $150 range.
I know there are a lot of variables, I am just looking for a "typical day of fishing on the lake" type of estimate.
Thanks
C) ???
Thanks
