Hi,<br /><br />I bough an old 25 hp Evinrude, it's a 1980 model. Got it cheap and I did not expect it to be perfect.<br />I have it running and idling good, the comp is 100 PSI + and I can't feel any play in the bearings by moving the flywheel or pushing on the pistons trough the plug holes.<br />Tried it on the boat today and it runs fine but I have one problem. On low revs and idle (in neutral or in gear) I can hear a distinct knocking sound from the powerhead area but I can't make out exactly where it comes from. The knocking is relative to the RPM and goes away in higher revs. I thought the engine felt a little raw on higher revs as well (more vibration than my even older Evinrude 18 hp).<br />Any ideas before I tear the powerhead down?<br /><br />Thank's in advance
