25 hp Sea king controls
blazzer66
I have a1974 montgomery ward sea king by chrysler, 25 hp. Will a uflex universal top mount single lever dual function control box work with my outboard and the teleflex 3300 cables. I have never hooked this stuff up before and am a little confused. Thanks alot, Mike
F_R
Re: 25 hp Sea king controls
I'm not familiar with uflex, but if it gives you the option of both push-to-open and pull-to-open throttles, it should work. The possible snag you might run into will be the connector hardware back at the motor end. I just don't know what the Chrysler takes.
blazzer66
I do have the right connections for the engine and the uflex does give an option for both push and pull so im good, thanks slot!
