Tin man 14
- Joined
- Mar 12, 2012
- 5
Have a 'recoil start' long shaft, 1985 Yamaha 25 hp two stroke. WAS working fine until I replaced the impeller. Now stuck in "F" and cannot engage other gears. Problem is NOT in the powehead. With Lower Unit removed shift linkage moves freely. Examining LU on workbench I cannot move shift rod. Not even sure (from Yamaha manual) if the rod is meant to move vertically or rotate. Answer to that Q, alone, will be very helpful. Propeller shaft and vertical drive shaft are 'linked' and rotating in a 'forward' direction. Any suggestions on how to address this shift problem? Thank you.
