25 hp Yamaha electric start
Benjinepa
Will not start when starting button pressed...Dead as a door nail! Battery fully charged, terminals tight, in neutral, fuse is fine....it will turn over when putting a screwdriver over selinoid terminals......Any suggestions?
Sea Rider
Remove cables from starting switch, connect a light tester or Ohm meter on electrical contacts, press the switch, if light does not come ON or with no continuity reading starting switch is kaputt. Replace.
Happy Boating
Benjinepa
Thanks guys/gals, I believe you are correct and it will be the switch. When I depress it, it is very firm even hard and the motor was stored in a heated basement for the past 2 years since I ran it on the St. Lawrence. Great engine can move a 14 ft deep v with three big men and gear at 25 mph, really. I want to keep it going, its a 1995 and quite frankly, dont want to spend the $$ to get a new one since I only use it 3-4 times a year...I will get back to you with the results...😃
Benjinepa
Back again guys...I'm no electrical genius, far from it. I'm much better at keeping a good home for my kids rather than doing man's work...so. I removed the starter switch and the contacts seemed a bit worn MAYBE even a bit burnt. I plugged the starter wires back into their appropriate mates and put a screwdriver over the terminals and nothing happened...even ran a wire to both of them without the switch, nothing....frustrated in PA...Shelly
Sea Rider
Check continuity between starter switch cables and starter motor contacts, probably inside cable is shot ?
Happy Boating
