1991 25HP
Broken pull cord. Replaced. Broke again, included spring. Replaced spring and cord. Next time out boat cut back to 75% power at WOT.
Compression 110 and 105
Replaced both ignition coils
Spark jumps 7/16 on both.
Installed carb kit and cleaned (both jets).
Replaced reeds.
Linc/sync is done (cam roller marks/butterfly positions)
Sea Foam decarb done
Replaced plugs QL77JC4
Test run results: Idled great. At WOT still at 75.....removed cowling and it ran FULL 100% WOT. Cut motor off. Started fine and ran well. Put cowling on and it did not run 100% WOT. Showed cough, sneeze, miss just above idle in mid range and would not get to top speed. Fuel line bulb gets soft and hard with the cough and sneeze (like it corrects itself). Stays hard at idle.
I am inclined to think it is in the high speed jet or fuel pump. I do not have experience to draw on to fix this. Seems it is fuel related or timing related as symptoms developed very soon after broken pull cord but what do I know. If it is fuel related what do you all think my next step is? Just take it to the dealer and pray? Cost may be more than it's worth at this point.
Thanks for this site.
Mark
Replaced reeds.
Mark
