duckhunter55
- Joined
- Oct 13, 2007
- 94
Hi, i have a 78 25 hp johnson and my problem is that the other day after replacing lower unit with new one i went to pull start motor, and the rope wants to keep the same tension the whole pull. usually the tension is strong at first then it lightens and fires. I took both plugs off and with them off it feels like normal and tries to start. both plug holes have compression. Could new lower unit and drive shaft have done something? ANy help greatly appreciated! thanks
