25 Johnson ..No Start...
Hearseman
Last time used (week ago) was starting fine (with electric starter)..Now no start..only have clicking in solenoid...How can I know if it's just the solenoid or is it the starter?? maybe something else?? I connected a jumper wire from the starter lug to the 12V lug to by pass the solenoid and could not get anything (no clicking at solenoid)...Please help with finding out the problem>>>Thanks..1989/90 25 HP Johnson 2cy electric starter Model J25TECEM
Xcusme
Re: 25 Johnson ..No Start...
Coffin,<br />Welcome to the forum. Check all of your connections before you suspect the starter or solenoid. Clean the Battery terminals, both heavy wired connections at the solenoid and at the starter connection. Don't forget to check the mounting bolts for the starter itself, they provide the ground connection for the starter. When you know that the connections are good, then test again. Jump the two heavy solenoid connections. If it doesn't spin, replace or test the starter itself. If the starter does spin, try using the key to start. If it does not spin the starter but you hear the solenoid click, replace the solenoid.
saffi
Bypass the solenoid, make sure you have a good battery (fully charged). Make sure you have the right cables and if the starter won't run you'll know where the problem lies.... Take the starter apart and check it.
Hearseman
Thanks to both replys....turned out to be the starter...
