25HP Johnson 1982 do I need regulator next to rectifier?
saffi
Hello again,
I realize that I asked this question before in 2004 but actually never got an answer (I did get very good answers to all my other questions).
In 2004 I installed a rectifier on my 1982 Johnson 25HP outboard to charge my battery. I used that engine to commute to work every day, mostly idle speed, and it worked very well.
The engine has been stored for two years now and I recently put it back into service again. It needed a new fuel pump and a complete rewiring a carburator overhaul but I love the way these old engines never seem to fail you.
When re-wiring the engine I checked the voltages coming out of the rectifier and noticed that when I rev the engine the (dc) voltage shoots up to 18 volts (no load, just volt meter attached). I have the battery directly attached to this rectifier and this doesn't seem good. The use of this engine will be changing now. I will be using it at high RPM for most of the time and low RPM coming into the lock, and to my home.
My question is, do I need a voltage regulator on top of the rectifier to properly charge the battery (12 volts, 80 amp, used for lights, water pump and charging my VHF etc...)?
Thanx in advance!
Vic.S
Re: 25HP Johnson 1982 do I need regulator next to rectifier?
18 volts is normal for the output from an unregulated rectifier with no load.
I assume the stator is 6amps maximum.
I would not bother with a regulator unless I found that with mostly high speed running the battery is being overcharged and needs frequent topping up .
Even then you have the option to switch the lights on to pull the volts down.
