imported_bowfisher
- Joined
- Jul 17, 2006
- 73
Finally got back to this motor I was having troubles with a few weeks ago.
Motor would not turn off with the key switch, replaced the power pack under the flywheel and now it shuts off. It will not rev up though.
Called Sierra to have the pack replaced, ordered a new pack thinking the replacement I ordered originally was bad out of the box.
Pack number two showed up, installed it, the same symptoms occur, wont rev up, acts like its hitting a rev limitter or going into SLOW mode.
Put the original pack back on (that wont shut off with key switch), motor revs up as it should.
So.... two new packs, same symptoms. Having a hard time believing two packs in a row could be bad.
Sierra part number 18-5794
Thoughts?
Thoughts?
