25p
bass_assasin
I have a 202pro v Blazer with a 200 xri.....it flies with that prop but it takes a bit to get on plane.....would a 23 help it without taking away from top speed...it runs 78-82 mph now
rndn
Re: 25p
What are your rpm's at wide open throttle with the 25" pitch prop?
steelespike
Re: 25p
also is my motor at the right height?
It appears it could go higher.If you have no venting problems now raise it to a point just before venting becomes a problem.Could help top speed and maybe hole shot a little.
72SideWinderSS
Re: 25p
Why the whale tail ?
It appears the jack plate is cranked all the way down, is it ?
bass_assasin
Re: 25p
This is the first jack plated boat I have owned and on my 21ft Laguna CC the whale tail helped the 150hp Black Max get up on plane at lower speeds. So I figured it might help on this one
72SideWinderSS
Re: 25p
I would do all of my testing/tuning without the whale tail, you may find you don't need it. At those speeds, at WOT, I would have concerns about stability issues.
If you feel the need for more low speed planing control, I would check into Smart Tabs.
You have never identified the prop you are running now, nor have you posted your WOT RPM's. With out this information, any recommendations are just a Wild ***** Guess.
What is the distance from the end of the pad (the lowest part of the hull) to the joint between the LU and Prop ? This will help in suggesting an initial height setting for your jack plate.
Be safe.
bass_assasin
Re: 25p
The prop is a tempest 48-825866 a45 25p
From the transom to the Lower unit is 19"
The lower unit gear housing(rounded part of foot) is Just below the lowest part of the boat
I have no intention of ever running the boat that fast, the guy I got it from was a speed freak, so he wanted the speed...I would be happy at 50-55mph tops and a better hole shot to get skiers or tubers going.Rpm's 5300 and that was fast enough for me...still had throttle left
72SideWinderSS
Re: 25p
If you are primarily using your boat for water sports/toys by all means prop down to a lower pitch.
Be aware that you may be able to exceed the recommended max RPM for your motor. Advise any one else that drives your boat of that condition.
A 21" pitch should give you an excellent hole shot and around 55 mph @ 5300 with approx. 10% slip.
A 23" pitch should give you a good hole shot and around 59 mph @ 5300 with approx. 10% slip.
What you do with your own boat is entirely up to you.
