bill bosox
- Joined
- Aug 1, 2008
- 2
I have a 1976 25 horse that skips under a load. The motor runs great at idle and fast idle but when you want to open it up, it will skip. This happened last fall and I sheared the prop pin.I have given a full tune up, points, condensers, all three coils and both plug wires. Plugs, fuel pump and rebuilt the carb. I went as far as to pull apart the lower unit thinking the gears were worn but they are new. I've timed the carb/points and tried changing the fuel. I thought it was fixed when I changed the fuel pump,but the skip came back on the return trip the first time out. Have I missed anything?
