28 HP Evinrude 1988 backfires & stalls in idle
Royce Brown
I have a 1988 Evinrude 28HP E28ESLCCR that runs really well aside from the fact that it will backfire & stall out when left in full idle.
I've played with what I believe is the low speed carb adjustment screw on the front by a full turn each direction, in 1/4 turn increments, same behavior throughout. My dad suspects it's a fuel pump issue because it has stalled out occasionally with more open throttle, only to find the primer bulb soft. A few pumps and it seems to pressurize itself. He thinks the fuel pump is the cause of fuel pressure loss and I can't disagree. I have no issue replacing the fuel pump & I have a full OEM service manual.
Also note this motor has had zero maintenance on it since birth aside from changing plugs each year, my dad ran it 6-8 times a year and it never failed to start/run consistently. If I were to guess this motor has maybe 250 hours on it, somewhere in that range.
Any suggestions? Run some kind of seafoam additive through it?
Cheers, Royce
jakedaawg
Fuel pump doubtful, primer bulb should NOT remain hard while running.
backfires in 2 strokes are more likely "lean sneezes". Not rich enough in one cylinder or a slight seal leak in crankcase most often.
Careful link and synch then more in depth diagnostic needed if it persists.
does it do it even after warmed up?
Sounds like the carburetor is opening too early.-----Move the stop screw on the rod towards the carburetor 1/8" and test run
Royce Brown
It does still stall out when warm. It does appear that the throttle plate is not quite aligned properly with the carb throttle assembly, need to adjust the linkage a bit and hopefully that solves my problem.
