'28 Johnson K-40 propshaft bearing clearance
FreeToMeBoating
Hello all -<br />This engine runs ok in test tank, but the propshaft on it is sloppy - I haven't measured but bearing/propshaft clearance (is it a bronze bushing perhaps?) feels excessive.<br />Does anyone know specs on this? Parts availability or source? Is a service manual available for it? TIA for any info.
JB
Re: '28 Johnson K-40 propshaft bearing clearance
Howdy, FTMB.<br /><br />Check with the guys at the Antique Outboard Motor Club, www.aomci.org<br /><br />They may be of help.<br /><br />Good luck. :)
seahorse5
K-40 gearcase specs<br /><br />clearance .0017-.0033 at the prop end<br /><br />shaft diameter .625 at prop end .624 at thrust end<br /><br />bushing dia. .6277
FreeToMeBoating
Seahorse -<br /><br />Thanks for the numbers-you're a real Johnson (!?!) :D
