28 or 29 default code
franck2b
Hello,<br />I have a 28 or 29 default code appears to my Yamaha F200 EFI tach.<br />Somebody knows what it means?<br />Thanks
rodbolt
Re: 28 or 29 default code
never seem a tach from yamaha that displays codes. it may be the tach is failing.<br /> a code 28 on the diagnostics indicates a shift position switch and code 29 indicates a intake air pressure sensor.
franck2b
Thanks rodbolt.<br />Can an intake valve stays closed, make a code 29?
rodbolt
no I dont think so. a stuck intake will cause a compression loss but that part of the mechanicals are not monitored by the computer.
