96 mariner 225efi. rather abrupt onset of failure of 2cycle oil to transfer from onboard reserve tank to engine mounted tank. I have inspected and tried every work around. With onboard tank connected to the crank case fitting, engine running around 2500 RPM not a drop of oil leaves the output port on the 3 gal tank. I can blow on the air input side and oil flow very easily. I connect to the engine mounted tank and with top off of tank I have to blow till my eyeballs pop out but oil will flow into the tank. This is a pretty simple system but I am missing something! Should I remove the ck valve on the engine block and ck that? Or is there something FUBAR with the oil pick up assembly in the 3gal tank? I did clean the screen with B12 and Brake cleaner and it appears clean as a whistle. Thanks for any help. My sanity is in your hands!
