ziggy
- Joined
- Jun 30, 2004
- 7,473
hi folks. i'm doing a carb. rebuild. down to putting it back together again. engine listed below. although. the carb. i'm rebuilding is off a 72 250 L6. i don't know if that one is the original carb. carb #7040083. the carb. on my aristocraft does appear to be the correct carb. #7043183. to late now. i used my new parts on the 7040083. the question i have regaurds the pump rod adjustment. should i just bend the pump rod on up to meet the .962" adj. from the top of the pump rod to the top of the airhorn w/throttle plates closed? i'm a 1/4'' short i bet.... or is there some other difference between these two carbs. that i'm not hip to...
