3.0 115HP Merc more low end prop ?
int76
Ok first for the boat info: 94 Glastron 17" SSV 175 with 3.0 Mercruiser 115HP currently the prop is brand new a 3 blade 13.75 x 21 (what it says on the prop). Well Im fixing to be adding a Big Air tower to the boat and want more low end pull to help out the wakeboarding situation. I could care less about top speed just want more low end. From what Ive gathered I think a 19 pitch 4 blade would do the trick, but what size? Any suggestions/recommendations are appreciated. Thanks - Josh
hwsiii
Re: 3.0 115HP Merc more low end prop ?
You need to tell me how many RPM you are getting with this prop.
H
Ayuh,... 19" of course,... Don't worry about diameter, you have No choice in the matter...
