the engine cuts out intermittently every few seconds for a split second. i tested the fuel pump<br />and it appears to be putting out a good stream to the carb. do i have an elecrical problem? the problem appeared suddenly, not over time.
Howdy, DMiller.<br /><br />Welcome to the board.<br /><br />Your engine sounds like an I/O. If that is true, you need to post your question (in a lot more detail) on the I/O and Inboards Forum.<br /><br />Good luck.
