3.0 ford 4cyl.omc cobra no reverse
bluethunder01071973
i just bought this 1990 sunbird. It has the 3.0 ford 4cyl motor with the cobra and the revese is out. looks like the guy i bought it from had the same problem and i was wondering how i can make this durable and not having to do this everytime i take it out. can the gears be interchangeable with stronger gears and i need help fixing this if anyone has pics and talk me thru this i would appreciate it very much. thanks mike:mad:
a70eliminator
Re: 3.0 ford 4cyl.omc cobra no reverse
Check page two of this forum Tazzz has the same problem same engine and same drive as you, maybe you can combine threads and join in somehow without hyjacking his thread.
But you should be taking a close look at the lower cable, maybe get lucky because if your reverse gear is blown up you'll require a total rebuild, any metal sparklies in the oil? grinding noises or other starange happenings?
Ayuh,....
If it's a 3.0l,... It's Not a Ford...
If it is a Ford,... It Ain't a 3.0l....
chiefalen
I missed that 2.3 ford 3.0 chevy. Ether way cable, if not bigger problems in the lower unit, pray it's the cable.
