Hi again guys, After the top dogs on here got me back up to performance with my boat i have another question.
3.0l mercrusier Serial no L663000. I have always had a loud clatter from the valve train side of my engine usually starting around 3500 RPM. Now i have adjusted the valves as per specifications i done pressure test after for piece of mind that i was still getting the same pressures on the cylinders which i was.
Now im sure its just the hydraulic lifters getting on in years. My question would be would it be ok just to change the lifters and then run them in as per a new engine?
Or is there anything but another valve adjustment to try?
