Need you thoughts on a 3.0 ignition problem I have with my engine. Took out the Dist to clean it up and paint it. Put it back in an timed it with #1 cylinder at tdc and Dist cap and rotory button pointing to the #1 plug. It ran for about 10 mins and when I attempted to set timing with light I notice that the timing mark on tdamper would not stabilize at either 4 or 6 deg. Now i it have current to the points, current at the coil wire when I ground it. But i get no current going to any of the plugs. from my Dist. I have used 2 different Dist Caps 3 different Coils, new plug wires along with 2 different rotor buttons but still no current to the plugs. I did not take off the advance weights or springs when cleaning...Anyone have any suggestions what I have missed or need to look for in getting to run...Thks
