as i have mentioned before in previous posts. i am trying to figure out what i can swap out with. do i have to stay with the 3.0 or can i drop down to a 2.5? if i do the drop in size how much power will i loose? will the boat still be able to pull tubes/skies? or does any one know if the 2.5 has the same block or at least the same crank journal sizes as the 3.0? what i was think about possibally doing or having done is take a 2.5 block (dad has one that has a bad crank that he will give me) and stuffing my 3.0 pistons rods and crank oputting my 3.0 head on it. maybe if need to have the clock line bored to fit the crank then have that done. or if can find a solid running 2.5 out of like an s10 and put all of my marine stuff on it. the only thing is with the research that i have done the s10 2.5 is only rated to right at 100 horse.
i forgot it is 17ft sunchaser 1702 tri hull deck boat with alapha 1 out drive
many thanks in andvance andy
