Re: 3.0 L will not get up on plane
If cyl 4 isn't firing, then it isn't likely to be a timing issue..<br /><br />did you check the actual plug on that cyl?<br />if not, change it for another cyl and try again. see if the problem moves to the other cylinder.. I have seen that happen.<br /><br />Check the compression on that cylinder, pull the plug, and stick your finger in the plug hole while its turning over.. if it has a hole in the piston of something else that would cause total lack of function, there will be practically no compression at all.. if it blows past your finger hard, then its probably got enough to at least fire..<br />pull another plug out and use that to compare between the two for compression..<br /><br />its not terribly accurate, but it will tell you if there is a big difference between the two..<br /><br />rgds<br /><br />Frank
