Re: 3.0 liter boggs
I see.
Well, I'm only 28, and have very very limited experience with mechanical fuel pumps. I'm assuming it's driven off your cam shaft.
I once bought a 1974 datsun 260z that had one, but I pulled the engine out the day after I bought it. =)
Ask the boating gods in here (don, bond-o, etc), how they would test it.
Off the top of my head, you could either
A) disconnect the line from your carb, remove your pump, pump it by hand, and ask the guys in here what you should expect for a reasonable amount of flow. (by hand I have no idea)
B) If you feel you can do it in a safe way, Put your boat on the muffs, heat up the engine, shut down the engine, disconnect the fuel line from the carb and put it in a jerry can, have someone else start the boat up (it will run with the fuel in the float at idle for quite a while), and while it's running, observe the flow of fuel into the jerry can.
